Thank you jimoshel... Those pictures helped quite a bit. My point about the fuel filler location on the tank is that if you left the filler neck/filler tube location alone, is that the tank is longer in front of the filler, and shorter behind. I totally didn't think to look at cab support clearance at the front of the tank... I guess that means I'm stuck with just buying a replacement tank and calling it good... What do you know about using an XJ fuel sender in an MJ tank? I can't find a new replacement for the MJ and I'd like to make the guage operational again but don't want to put used junk in a new tank if avoidable...
