moondog Posted May 22, 2010 Share Posted May 22, 2010 :fs1: I replaced my fuel injectors with the reman ones I saw on this site and my truck runs great now but ihad a fuel leak. I looked around and found it. Its leaking at the regulator connection. I bought some new orings from Rock Auto but I can't get the fitting back togather at the fuel regulator. It doesnt want to go in far enough. I think I got all the old oring out. please help my truck is a dd. Link to comment Share on other sites More sharing options...
moondog Posted May 22, 2010 Author Share Posted May 22, 2010 I forgot 88 4.0 Link to comment Share on other sites More sharing options...
sinkrun Posted May 22, 2010 Share Posted May 22, 2010 Had the same problem on my 89 found a replacement end it was dorman I think at Fishers auto. You do have to cut the crimped one off the rubber line I used 2 clamps just for that little extra insurance never had any issues with leaks again. Link to comment Share on other sites More sharing options...
moondog Posted May 22, 2010 Author Share Posted May 22, 2010 I have some orings but they are too thick. I tried som from the auto parts store way too thin still leaking. Link to comment Share on other sites More sharing options...
Wildman Posted May 23, 2010 Share Posted May 23, 2010 There is a "repair" kit hanging in you local auto parts store in the "Help" section, it's the O-rings and the replacement quick dis-connect. The OEM quick dis-connects are not re-usable, and should be replaced with new one. Â And No, I don't know the part number off hand :dunno: Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 23, 2010 Share Posted May 23, 2010 OR you can pickup the fuel line quik-connect repair kit from the dealership (p/n 8350 2745). Â There is also a fuel rail seal kit available from the dealer (p/n 83503637, about $12) that has the o-rings for the regulator and all the injectors. :cheers: Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 23, 2010 Share Posted May 23, 2010 IIRC, it goes o-ring, spacer, oring (the spacer being the little plastic ring...should pop right in. Link to comment Share on other sites More sharing options...
moondog Posted May 23, 2010 Author Share Posted May 23, 2010 OK thanks I will try the repair kit. It seems like it just won't go in far enough. Link to comment Share on other sites More sharing options...
sinkrun Posted May 23, 2010 Share Posted May 23, 2010 As I siad mine did the same even with the repair kit $8.00 fitting and I was up and running. Link to comment Share on other sites More sharing options...
Wallyman Posted May 24, 2010 Share Posted May 24, 2010 I really have a dislike for the quick disconnects used on these lines. (theres one on the heater hose connection on my 454 vortec also, really, the heater hose?) Sometimes i have to get a small flat blade driver to pry the clips into place. That may not tbe the right way but once they are in theres no leaks. Make sure you have the brown o rings, not regular black ones. there are specific fuel o rings. Link to comment Share on other sites More sharing options...
Oizarod115 Posted May 24, 2010 Share Posted May 24, 2010 try a little grease on the o-rings Link to comment Share on other sites More sharing options...
