Exhaust manifold bolt size
I checked the FAQ and didn't see it in the bolt thread, looking for the bolt size to attach the intake/exhaust manifolds to the head. Just bought an '89 2.5L 'manche and it's missing 4 of the 7 or so bolts holding the manifolds on. Thanks.
I'm not home right now so I can't check for sure but 3/8-16 comes to mind for the bolts. There is a stud on the front exhaust #1 that is a different size.
Ace hardware carries the good grade 8 bolts. It is important to use the factory conical washers. They are designed to absorb the varied expansion and contraction of the dissimular metals, aluminum and cast iron.
  • 4 years later...
