87 2.5 4x2 4 speed.
Backed up and parked.
Went to leave .... NO CLUTCH PEDAL RESISTANCE and DOES NOT DISENGAGE!
Clutch master cyl is full.
So, not a leak, but for it to INSTANTLY be bad. What you think? Master or slave cyl! GOTTA FIX TODAY!!!!!
BTW, when i pump it, no fluid movement in the master cyl.
If the hose burst or the slave failed, there would be a leak. If the slave let go you should be able to look underneath and see fluid dripping out of the bellhousing. If the hose burst, the outside of the hose will be wet (and it may be dripping off the hose or hard line at the lowest point).
If you have pumped the peddle multiple times and still have no peddle, and there's no evidence of fluid where a burst hose or slave would cause fluid to show up ... most likely the master.
The pushrod from the peddle is still connected to the slave, right?
Twas master. New one in (what a hassle to change!), and all working good! Actually has some "feel" to the pedal rather than a "soft" touch I did not notice slowly coming about!
Thanks for the advice!
