pug Posted May 1, 2010 Share Posted May 1, 2010 What is best name brand gears to buy for 8.8. thanks Link to comment Share on other sites More sharing options...
cracker Posted May 1, 2010 Share Posted May 1, 2010 I have liked Precision over the years. Actually, I really have never had a gear issue with ayones gears including Yukon, Genuine Gear, Dana, Precision, etc. The most important thing is that you get some one really good to set them up. Good luck. Link to comment Share on other sites More sharing options...
pug Posted May 1, 2010 Author Share Posted May 1, 2010 Getting somebody to set the gears won't be a problem. Just wanted to have a good set of gears. I only heard do not buy the cheap set. Link to comment Share on other sites More sharing options...
cracker Posted May 1, 2010 Share Posted May 1, 2010 I forgot that Richmond has been pretty nice gears (along with Precision) too. Richmond cut the gears in my TrueHi9 and so far so good :thumbsup: Link to comment Share on other sites More sharing options...
Pete M Posted May 1, 2010 Share Posted May 1, 2010 in my TrueHi9 :drool: Link to comment Share on other sites More sharing options...
pug Posted May 3, 2010 Author Share Posted May 3, 2010 How do you tell if you need reverse rotation gears or regulare gears also has anybody used yukon gears. thanks Link to comment Share on other sites More sharing options...
Pete M Posted May 3, 2010 Share Posted May 3, 2010 "reverse rotation" is an improper term. nothing actually rotates in reverse. A more correct term is reverse cut, since the ring gear teeth are cut in the other direction. High pinion differentials use reverse cut gears. Low pinion diffs use regular cut gears. :thumbsup: Link to comment Share on other sites More sharing options...
pug Posted May 3, 2010 Author Share Posted May 3, 2010 So is a 1998 8.8 out of explorer a high pinion or is there a serial #. Link to comment Share on other sites More sharing options...
Pete M Posted May 3, 2010 Share Posted May 3, 2010 low pinion. almost every rear axle ever is low pinion. :thumbsup: low pinion on the left, high on the right: Link to comment Share on other sites More sharing options...
