I plan on pulling my headliner backing sometime in the next week and before i get into it, i was wondering how its held in. I don't want to damage it since it is in relatively good shape. My other question was on the rear speakers (b pillar) what size are they? i think 6 x 4 but just making sure, slowly starting to upgrade things now that most mechanical things are fixed :cheers:
The headliner is held on the sides by two metal clips that are under the plastic trim, then there is two pieces of industrial grade Velcro on the front and rear of the headliner. The glue that holds them on the backer probably won't survive the removal, mine didn't but when I put the new fabric on I just reglued them on also then put a couple staples thru them.
speakers are not 6x4... they are actually 4x6 :clapping:
but I'm pretty sure 6x4s will fit.
That depends on how you look at em :brows: :nuts:
I needa do my headliner too, Take pics!
