STERLING STINGER Posted April 13, 2010 Posted April 13, 2010 I'm looking for tie rods, complete set if possible. Anyone got any spares laying around? For my 88 mj thanks, Paul
CWLONGSHOT Posted April 13, 2010 Posted April 13, 2010 Hit the local pick-N-pull and grab a complete setup, Drag Link. Tie-rod, Pitman arm and tie-rod ends!! GREAT for trail spares!! If you where closer I could hook you up as all mine are running the JCR 1TON stuff so stock stuff is useless to me.. CW
jeepjunkee Posted April 14, 2010 Posted April 14, 2010 Hit the local pick-N-pull and grab a complete setup, Drag Link. Tie-rod, Pitman arm and tie-rod ends!! GREAT for trail spares!! If you where closer I could hook you up as all mine are running the JCR 1TON stuff so stock stuff is useless to me.. CW :hijack: How is that jcr 1-ton steering i was thinking of getting that but wanted some input. Was it hard to put on? Like the reaming to the spindle/knuckle
STERLING STINGER Posted April 14, 2010 Author Posted April 14, 2010 Whats the years i can get this from cw?
CWLONGSHOT Posted April 14, 2010 Posted April 14, 2010 I like it allot, reaming its too hard. The Pitman arm is harder..cause its harder. :roll: :yes: Read all about it in my build thread. Most years will work just fine, as will ZJ and TJ setups. ZJ V8 setups will be heavier duty. CW
whowey Posted April 14, 2010 Posted April 14, 2010 I can send you a complete V-8 ZJ set-up for $60 plus shipping. Direct bolt in.. but its solid Tie Rod and thicker ends rather than the hollow MJ/XJ version.
STERLING STINGER Posted April 14, 2010 Author Posted April 14, 2010 I can send you a complete V-8 ZJ set-up for $60 plus shipping. Direct bolt in.. but its solid Tie Rod and thicker ends rather than the hollow MJ/XJ version. Pmed
