smithe1811 Posted April 13, 2010 Posted April 13, 2010 looked in my haynes and it only has the ax/15 info, wanted to know if anyone had a pic of the fill and drain holes for the ba/10 on my 88.
Automan2164 Posted April 13, 2010 Posted April 13, 2010 There are a couple of plugs on the passengers side of the trans, about halfway up the case. One drain, one fill IIRC. Been awhile. The thing I do remember, is the size of the square in the plug. Looks like a standard socket drive, but its kinda inbetween. I had to grind down a big bolt until it fit in, and now I always have a tool for them. Rob L.
smithe1811 Posted April 14, 2010 Author Posted April 14, 2010 i found what i think is the fill plug, but i don't now which is the drain, there are just a couple of regular looking bolts there. and i see what you mean about that plug having an odd size square on it.
comanche09 Posted April 14, 2010 Posted April 14, 2010 :headpop: Yet another reason why the Peugeot trans SUX On the 2wd BA/10 (don't know about the 4x4 version) the drain is at the back of the case below the tailcone. I had to grind down a piece of square stock to make a tool for the plugs. I could never get the fill plug free (kept bending deflecting the steel stock). I was able to fill the trans by unbolting the shifter in the cab...
smithe1811 Posted April 14, 2010 Author Posted April 14, 2010 :wall: i really don't want to pay to have my transmission fluid changed, there has to be someone here with a 4x4 ba/10-5 that has changed their own fluid before that can perhaps take a minute to snap a pic for me of both plugs.
dasbrick Posted April 14, 2010 Posted April 14, 2010 Guess what. Most places that do the oil changes won't touch it because they don't have the tool. Took mine to valvoline, penzoil, some others, and they all scratched their heads.
Wildman Posted April 14, 2010 Posted April 14, 2010 I just looked real quick for pictures too........nothing came up :hmm: If you found the fill plug on the passenger side, the drain plug looks the same, on the rear, bottom of the tranny, facing towards the back. As noted.......make sure the fill plug will come out first, before attempting to remove the drain plug. I too took an odd 3/8" extension, and ground that down, but......you can now buy a kit if you want at harbor fright with square metric internal sockets. You need a suction gun to fill the tranny, with 5.2 pints for 2wd OR 4.9 pints for 4wd, with what every your putting in there. Or....you can fill it from the shifter......if you want to take that all apart.
BORDENCOMANCHE Posted April 14, 2010 Posted April 14, 2010 I have a 4x4 ba10/5, look between the transfer case and the transmission you will see what is called an adapter plate bolted to both the transmission and the transfercase (I have NP 231), On the bottom of the adapter plate is the drain hole. If I am not mistaken.
smithe1811 Posted April 14, 2010 Author Posted April 14, 2010 well, once i get some more time to head back out there and look i will make sure to get pics(if i find the plugs) for the useful info thread!
ParadiseMJ Posted April 15, 2010 Posted April 15, 2010 http://www.jeepforum.com/forum/f12/how- ... up-652142/
smithe1811 Posted April 15, 2010 Author Posted April 15, 2010 http://www.jeepforum.com/forum/f12/how-ba-10-5-tranny-fluid-change-write-up-652142/ :bowdown: :bowdown:
one_bad_MJ Posted April 17, 2010 Posted April 17, 2010 Guess what. Most places that do the oil changes won't touch it because they don't have the tool. Took mine to valvoline, penzoil, some others, and they all scratched their heads. allen wrench just grind it a little bit to fit
