75sv1 Posted March 29, 2010 Share Posted March 29, 2010 New hear, but have been on other Jeep Boards. I am getting close to doing a lift on my '88 Comanche. I am going with a Ford 8.8 with 4:10 ratio. I don't have the rear end yet. I have been looking at Rusty's rear leaf springs. I think this board likes Hell's Creek's. I will check into them. I didn't see any price or even lift kits on their website though. I want to retain the axle over the springs. Since the Ford 8.8 is about 3-5/16 OD and the D35 is about 2-1/2. So there is about 3/8 difference. Is that much to worry about, etc. I will probably be putting a Dana 44 latter for the front axle. Mine is 2wd at the moment. I have a NV3550 for the tranny and a Dana 300 for the TC. That will be getting a 4:1 gear kit. Any suggestions welcomed. Tom Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2010 Share Posted March 29, 2010 what vehicle did the 8.8 come from? What vehicle is the Dana 44 coming from? Link to comment Share on other sites More sharing options...
75sv1 Posted March 29, 2010 Author Share Posted March 29, 2010 Pete, I'll be getting a Ford 8.8 from a 95 or Newer Ford Exploerer. That's for the rear disk brakes. I haven't selected a Dana 44, but probably from a Jeep CJ-7. For my setup, I am going with a passenger drop. That way, I don't need a clocking ring. I have already drilled the NV3550 for the bolt holes. I am looking at the MJ 3" lift in the For Sales section. I'll have to check is those shocks would work for 4 to 4.5 inch lift. Also, weather I can use spacers for those springs. Tom Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2010 Share Posted March 29, 2010 how are you working around the different rim bolt patterns on the CJ/Explorer axles? Where are you routing the exhaust? Link to comment Share on other sites More sharing options...
75sv1 Posted March 29, 2010 Author Share Posted March 29, 2010 Pete, The Exploerer should have the same BC as the MJ. I haven't worked out the Dana 44, yet. That is a future project. I could possibly get some Moser axles drilled for the MJ's present BC. As far as the exhaust, I am thinking of running it straight back. I will have to see how that interferes with the gas tank. I might have to put the gas tank on the passenger side. Tom Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2010 Share Posted March 29, 2010 When did CJs come with a Dana 44 front axle? I realize I only have a cursory knowledge of them, but I thought they had low pinion Dana 30s. :dunno: and I'd be mad at myself if I didn't at least mention that you could save yourself a lot of headaches by running an NP-231. Why did you choose to go with the Dana 300? Link to comment Share on other sites More sharing options...
75sv1 Posted March 29, 2010 Author Share Posted March 29, 2010 Pete, You may be right on the CJ axles. I went with the Dana 300, I guess more for I wanted to be different. With twin sticks and 4:1 ratio it will give me flexibility of FW, RW and 4WD in both Hi and Low. I'll probably never use it though. Tom Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2010 Share Posted March 29, 2010 I've had the same thoughts :D , and while it'd be a cool thing to have, I went with a 99 231 t-case because the amount of work to adapt to the 300 became just crazy (or crazy expensive). Thought about a flip kit to the 300? There really isn't any good front axle options that are a passenger side drop, except maybe a Dana 60, and even that is low pinion like the rest. Link to comment Share on other sites More sharing options...
75sv1 Posted March 29, 2010 Author Share Posted March 29, 2010 I never really though about a flip kit. I think there are other options on a Passenger side drop. I haven't really looked at that problem in a while. My main concern at the present is the Ford 8.8 and what I need to do to get an even lift, Front and rear. Rusty's list a 4.5" lift kit. Then the rear springs on their site says 4" lift. I didn't know about Hell Creek spring options. The Metric Ton springs with their long AAL might work. I just didn't see link to it on their website. I was originally looking at DPG for some front spring or RE setup. Still, a bit expensive. I might have to see what the rear lift nets and then match springs to that. Spacer or the adjustable spacer might work out. Mine will be a daily driver, so some ride comfort is wanted/needed. Tom I did a websearch: '74-'79 Wagoneer Narrow-Track Dana 44 Differential Location: Passenger side Lug Pattern: 6-on-5.5 Good For: At about 60 inches wide it's a good streetable swap for most Jeeps with a passenger drop T-case Pros: Very common in wrecking yards, heavy-duty axle tubes, cheap, easy to convert to other popular lug patterns with bolt-on junkyard parts Cons: Will need to outboard mount leaf springs if used on CJ or YJ Identified By: Stop sign like diff cover, spring-under housing, 60 inches wide '74-'79 Cherokee Chief/J-Truck Wide-Track Dana 44 Differential Location: Passenger side Lug Pattern: 6-on-5.5 and 8-on-6.5 (some truck) Good For: It's basically a full-width axle (66 inches wide), good for light-duty full-width conversions on CJs, YJs, TJs, XJs and others with a swapped in passenger side drop T-case Pros: Fairly common, heavy-duty axle tubes, easy to convert to other popular lug patterns with bolt-on junkyard parts Cons: Will need to outboard-mount leaf springs if used on CJ or YJ, spring-under housing Identified By: Stop sign like diff cover, spring-under housing, 66 inches wide So at least one option. Maybe a few inches wide and the bolt pattern is different. Still, doable. Link to comment Share on other sites More sharing options...
Pete M Posted March 29, 2010 Share Posted March 29, 2010 If you go with the widetrack version, then a great match is a rear Dana 44 from a 95ish v6 Isuzu Rodeo/Honda Passport. It's got disk brakes, same width and 6 bolt pattern as the widetrack Jeep, and comes with either 4.10 or 4.30 gears. The only glitch is the flange needs to be swapped for a U-bolt flange. Height numbers for springs are always a crapshoot. They all have a "range". Yeah, the hellcreek website isn't the greatest. :dunno: check the thread in the classifieds and send him a PM with your needs. :thumbsup: Link to comment Share on other sites More sharing options...
