Not a happy starter
went to change out the valve cover gasket today, but i couldn't get the back bolt, so i put it all back together. The only line i removed was the one running from the cover to the intake manifold, a vacuum line i think. Now when i start it, it runs real rough and then settles out, but its bothering me now, it also does this when i start it after sitting a while. CPS? not sure though
I have a '89 2.5 that did that. Start it every day no problem. The longer it sat the harder it was to start. Sit for 3 days it was almost impossible to start. I disconnected the CPS plug and reconnected it. No brake cleaner or nothing, just unplug and replug the connector. Haven't had any trouble since. Jim
Image Not Found
Is this the CPS, i just looked quick an its the only thing i could find on the bell housing. If it is, how do i take it apart, its raining right now and i didn't get a chance to really look at it
