wiring
went back to wiring the jeep a couple of weeks ago. finally installed the dash. hopefully i won't need to remove it again.
you can view the other pics at photobucket then dakale then wiring album
not done. hooking up the gauge wires ,speedo sender, fuel pump and lots of individual ground wires to a grounding block. then i'll see if it runs before i dress the wires. i have different spot lights and other aftermarket stuff, but i can do those one at a time :brows: .
glad to be this close.
i work on it every day depending on time. its in my garage so weather isn't a problem.
this is a pic of the electric sender for the ax-15 which is for any trans from what i gather
i am removing the senders and replacing them with the autometer senders. i will have a full gauge --- and the senders including the oil pressure sender in the classifies soon.
Wow, that black dash is in beautiful shape! :eek: I have yet to find one in the yard that wasn't cracked up and faded.
I need a driverside black dash.
I think they stopped making the black dash in '87 with the Chrysler takeover :(
