SO CLOSE, yet SO FAR AWAY!!
Okay just as I connect everything in my 4x4 swap I decided to test the comanche in the 2 and a half feet of snow in my back yard, I put it in 4 hi, drives right into the snow no problem. I go to reverse and back up, BOOM! I snap the yoke strap bolts on the front to one side of the U-joint.
The result, I now have a UJoint Cap in one side of my Yoke still strapped down and on the other side I have two studs with no heads in them, jammed into the holes.
Can I simply drill out my busted studs and replace the U joint??
Bell.
