jeephack Posted February 27, 2010 Share Posted February 27, 2010 After much investigation and testing on my electrical problems, I have come to the unhappy conclusion that my fuse block is not realistically salvageable. I have one in my parts Cherokee that is nearly pristine. My question is... I know there is no easy way to perform this transplant, but what is the least painful way to accomplish this? I know some of you guys on here have done this before. May I impose upon you for your experienced guidance? All help greatly appreciated. Jeephack Link to comment Share on other sites More sharing options...
Wildman Posted February 28, 2010 Share Posted February 28, 2010 It's really not too complicated to swap in a XJ fuse panel/interior harness in place of the MJ's. The only real problem you'll encounter is the whip to the rear, and with a little tracing and detective work, it will be solved ;) Here's some reference topics for you to ponder - viewtopic.php?f=2&t=20922&hilit=xj+wire+harness And here's the one on the rear light that mfpdm put together - viewtopic.php?f=9&t=19695&hilit=xj+wire+harness What you'll want to check is if the engine bay side of the fuse block is still in good shape, if in dough, then the XJ's engine harness should be a direct replacement. Oh, one question.........is the MJ and XJ still in the same era????? like '87 - '90 Renix era?? Link to comment Share on other sites More sharing options...
jeephack Posted February 28, 2010 Author Share Posted February 28, 2010 Thanks Wildman. Most helpful. And yes, the MJ is an '87, The XJ is a '90. Link to comment Share on other sites More sharing options...
JENSSEN Posted February 15, 2011 Share Posted February 15, 2011 I have a damage block on my manche, does all kinds of weird stuff if it gets wiggled,... I will be attacking that project soon Link to comment Share on other sites More sharing options...
whowey Posted February 15, 2011 Share Posted February 15, 2011 I have a plywood fuse box... gotta love OOs... Link to comment Share on other sites More sharing options...
