Dadinator Posted October 3, 2006 Posted October 3, 2006 Will a front axle from an 86 Cherokee fit on a 90 Comanche? Both 4X4. I don't know anything about the Cherokee yet. Haven't seen it. Thanks!
DirtyComanche Posted October 3, 2006 Posted October 3, 2006 It'll fit. Gear ratios might give you headaches.
Eagle Posted October 3, 2006 Posted October 3, 2006 Don't try to use rotors, hubs or calipers off the 90 on the 86 axle. They aren't the same. If you use the 86 axle, it'll bolt right in but you have to use hubs, rotors and brake parts for the year of the axle, not for the year of the chassis.
87manche Posted October 3, 2006 Posted October 3, 2006 could be worse, I've got 97 unit bearings, 97 rotors and 90 calipers :nuts: functionally the 86 axle should be the same. it may have CV joints that suck, but you can replace those with the inners and outers for u-joints. You might even be able to use the ones from the wrecked axle if they're not damaged.
Hot Rod Jeep Posted October 3, 2006 Posted October 3, 2006 Someone told me that all XJ's have high pinion 30's, is that true? 8)
feerocknok Posted October 3, 2006 Posted October 3, 2006 Someone told me that all XJ's have high pinion 30's, is that true? 8) I believe that 2001 was the only year they didn't. All MJs have em.
Hot Rod Jeep Posted October 4, 2006 Posted October 4, 2006 I believe that 2001 was the only year they didn't. All MJs have em. I knew some MJ's had them, I didn't know all MJ's did. 8)
