Dadinator Posted October 3, 2006 Share Posted October 3, 2006 Will a front axle from an 86 Cherokee fit on a 90 Comanche? Both 4X4. I don't know anything about the Cherokee yet. Haven't seen it. Thanks! Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted October 3, 2006 Share Posted October 3, 2006 It'll fit. Gear ratios might give you headaches. Quote Link to comment Share on other sites More sharing options...
Eagle Posted October 3, 2006 Share Posted October 3, 2006 Don't try to use rotors, hubs or calipers off the 90 on the 86 axle. They aren't the same. If you use the 86 axle, it'll bolt right in but you have to use hubs, rotors and brake parts for the year of the axle, not for the year of the chassis. Quote Link to comment Share on other sites More sharing options...
87manche Posted October 3, 2006 Share Posted October 3, 2006 could be worse, I've got 97 unit bearings, 97 rotors and 90 calipers :nuts: functionally the 86 axle should be the same. it may have CV joints that suck, but you can replace those with the inners and outers for u-joints. You might even be able to use the ones from the wrecked axle if they're not damaged. Quote Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted October 3, 2006 Share Posted October 3, 2006 Someone told me that all XJ's have high pinion 30's, is that true? 8) Quote Link to comment Share on other sites More sharing options...
feerocknok Posted October 3, 2006 Share Posted October 3, 2006 Someone told me that all XJ's have high pinion 30's, is that true? 8) I believe that 2001 was the only year they didn't. All MJs have em. Quote Link to comment Share on other sites More sharing options...
jbhill Posted October 3, 2006 Share Posted October 3, 2006 all the body stuff will bolt right up. Quote Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted October 4, 2006 Share Posted October 4, 2006 I believe that 2001 was the only year they didn't. All MJs have em. I knew some MJ's had them, I didn't know all MJ's did. 8) Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
