88pioneer Posted January 23, 2010 Share Posted January 23, 2010 I bought some new cheapo front shocks for my XJ today, and was going to install them. I ran into the same problem i had when i switched the ones on the MJ. The bottom bolts come off easy, but the nut for the top is always stuck to the stud on the shock. On the MJ i could just hold the dust cover part an keep it from spinning and they came right off, but the on the XJ the dust cover just spins. I was either thinking of clamping on a set of vice grips an wedging them into the wheel well an trying to get the nut off the top of the shock. Looking for anyone who has gone through this and what they did. Thanks :cheers: Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 23, 2010 Share Posted January 23, 2010 Yes, that's usually how it's done; holding the shaft w. vicegrips. Some shocks also have a flat on the shaft up near the top you can get an open end wrench on. And use antiseize on the new ones so they'll come out easier next time. :D Link to comment Share on other sites More sharing options...
Wildman Posted January 24, 2010 Share Posted January 24, 2010 Or........cut/peel a section of the dust shield back so you can get a pair of vice-grips on the shaft. Another reason I like the Gabriel shocks, at least they still put a hex nut at the top of the shafts, under the washer ;) Link to comment Share on other sites More sharing options...
88SporTruck Posted January 24, 2010 Share Posted January 24, 2010 cut the shaft with an angle grinder and pull it out the top if possible. Youll be done in 5 minutes or less. If you can't pull a long shaft out the top then hold it with vise grips and undo the nut. If your trashing the shock it won't matter how bad you mess up the shaft trying to grip it. Link to comment Share on other sites More sharing options...
88pioneer Posted January 24, 2010 Author Share Posted January 24, 2010 Yea i figured the vice grips would work, i cut the dust shield away already so thats done, and i guess its good i'm putting Gabriel's in it ;), Thanks for the help :cheers: Link to comment Share on other sites More sharing options...
