jeep stuff Posted January 17, 2010 Share Posted January 17, 2010 my heat works but i think the switch is bad becouse the settings don't work only the vent does any ideas how to get it to switch cuz my feet freeze after 10 min its like 5 degrees outside Link to comment Share on other sites More sharing options...
james750 Posted January 17, 2010 Share Posted January 17, 2010 Is it only blowing out your defrost vents? If so 9/10 chances your vacuum bottle behind the front right headlight is leaking. Link to comment Share on other sites More sharing options...
beaterjeep Posted January 17, 2010 Share Posted January 17, 2010 :agree: More often than not, it comes down to a vacuum issue with either the lines going into the HVAC unit itself, along the path of the dash to under the hood, or the vacuum canister itself. The canister is the little either football shaped or round ball located behind the passenger side of your front bumper. My best advice would be to check there first and report back. Also, PLEASE use punctuation in your posts. Having everything into one large sentence makes the whole thing very indiscernible to know for sure what it is you're saying or asking. Link to comment Share on other sites More sharing options...
Eagle Posted January 17, 2010 Share Posted January 17, 2010 :agree: :agree: To amplify a bit on the above -- the flappers in the dashboard that direct the airflow are controlled by vacuum. In the event of low (or no) vacuum, the default position is to direct the air to the defroster outlets on top of the dash. The most common cause is that the vacuum tubes disintegrate somewhere in the area of the battery tray, but a cracked vacuum reservoir (sometimes referred to as the "softball" or the "blimp" behind the front bumper would also result in low vacuum. Link to comment Share on other sites More sharing options...
jeep stuff Posted January 17, 2010 Author Share Posted January 17, 2010 well ill take some pics because i don't think everything is hooked up right under my hood. i pulled the lines off that hvac and there was no pressure in any of the 4 lines going in it Link to comment Share on other sites More sharing options...
