offroader461 Posted September 21, 2006 Share Posted September 21, 2006 Hey guys...i got my 87 MJ and its got the puegot tranny in it...well about 6mnths ago the darn thing blew up so i only had 3 and 4 gear so i decided since money at the time was cheap to just replace instead of swapping...now i got a rebuild that a reputable shop built for me but now i am having a problem that only shows up every so often...what will happen is it will just mysteriously jump out of 1st gear and only that one?? now i know its not the syncro cuz the guy at the shop had to tear it back apart last week to replace it(burned out)...could i fix this by putting different fluid in or what I'm so annoyed and unfortunantly its my DD help me i am running val 75w-90 in it now thx MJ rule Link to comment Share on other sites More sharing options...
sinnaevd Posted September 22, 2006 Share Posted September 22, 2006 i know of a few ppl who ohave had the same problem and can not figure it out after changing oil and a bunch of other little things. if you can afforod it, switch to an ax15, and keep ur mind at ease :cheers: Link to comment Share on other sites More sharing options...
Eagle Posted September 22, 2006 Share Posted September 22, 2006 The fact that the synchro "burned out" should be a clue. A synchronizer is not a clutch, and it can't "burn out." It's a splined collar that slides onto a splined shaft, much the way the front axle disconnect works. If a syncro failed in a freshly rebuit tranny, it's most likely because the linkage isn't adjusted correctly and the synchro is not engaging fully. That would initially put extra stress on whatever percentage of the splines ARE engaging (meaning what percentage of the length, not how many), and as the stress begins to wear at them, that's when it begins to pop out of gear. Link to comment Share on other sites More sharing options...
offroader461 Posted September 22, 2006 Author Share Posted September 22, 2006 yea your right i worded it wrong...he gave me the old syncro and the ribs on the silver color were completley gone the surface was smooth unlike the other side it was still ribbed...now i know the answer will probably be no but is there anyway that the adjustments can be made with the trans still in the truck since its my DD....can't afford to have this thing down again for another week while he fudges around with this. Link to comment Share on other sites More sharing options...
Pete M Posted September 22, 2006 Share Posted September 22, 2006 If it was me I'd just deal with it and start the AX-15 search. car-part.com can help you out finding one. Just use second gear unless you come to a complete stop. :D Link to comment Share on other sites More sharing options...
Eagle Posted September 22, 2006 Share Posted September 22, 2006 Can't be adjusted in the truck. The "linkage" isn't an external, like the old 60's vintage muscle cars with their Hurst shifters. The shift handle goes into the top of the tranny and any adjustment has to be made internally (and I don't even know if there is any "adjustment" possible, other than assembling it correctly). Link to comment Share on other sites More sharing options...
