freakjeep93 Posted December 29, 2009 Share Posted December 29, 2009 my kawasaki bayou 400 isnt running right . it won't idle amd at really low rpms its missing. ive gto a hunch that my problem is in the carb setting somewhere but i don't know where . will turning my idle uo help? Link to comment Share on other sites More sharing options...
valis Posted December 29, 2009 Share Posted December 29, 2009 Sounds like it needs a good carb cleaning. My Honda Rancher 350 did the same thing and ran great after I went through the carb and cleaned the snot of out it. Link to comment Share on other sites More sharing options...
88mjmanche Posted December 29, 2009 Share Posted December 29, 2009 check you air box might be a mouse nest pluggen it up :ack: Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 29, 2009 Author Share Posted December 29, 2009 alright . my dad says that turnin the idle up some will help it to stay goin . ill check the air box too but ive got a k&n air filter so it should be good Link to comment Share on other sites More sharing options...
89eliminator Posted December 29, 2009 Share Posted December 29, 2009 carb issue for sure. the jets are probably clogged. easy fix. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 29, 2009 Author Share Posted December 29, 2009 yea I'm gunna try turning the idle up a little bit tomorrow and see what happens . if it don't work then ill run a bottle of carb cleaner through it and if THAt doesnt work illtake it apart Link to comment Share on other sites More sharing options...
