I just recently purchased my second MJ and it needs a rear axle, it currently has a Dana 35 thats all sorts of messed up. I have an 87 Jeep Cherokee and a 99 Grand cherokee both for parts, but neither axle will work, the grand cherokee is coils and the cherokee is sprung over and I need a sprung under Dana 35 or whatever will bolt in. I have cash or I can trade parts off both my jeeps. Please call me if you have anything that will work or if you know what axle I can just bolt in that would work. I can pay to ship as long as its less than 100 miles or I can pick up. Thanks everyone. My cell number is 757-717-8813
there is (was, maybe...haven't been down in a week or so) an MJ in the local 'yard up here. Last I saw it the rear 35 was still there...
that said, you can get a set of new spring perches (JEGS, Mopar, etc.) for about $20 shipped to you, and get them welded on the XJ axle for short change.
Jeff
getting the right gear ratio is far more important than perch location. getting perches welded on is pretty easy. :thumbsup:
I can do gears myself, I just next the whole axle so I can get it inspected. The axle in my comanche is so messed up its not worth fixing. Is there any axles that would just bolt in so I could at least drive it?
-Thanks
Brenton
Only an MJ axle will bolt-on. but it's real easy to get perches burned onto that XJ axle. check with your local muffler shop.
