WBKrazy Posted December 15, 2009 Share Posted December 15, 2009 did you remove the clutch master cylinder? and if so what did you use to cover the hole in the firewall? I'm pretty sure i'm going to take it out so it doesn't wind up puking on the fusebox, just looking for ideas to plug the hole up..... Link to comment Share on other sites More sharing options...
Jeepman Posted December 15, 2009 Share Posted December 15, 2009 When I converted to Auto I Actually Just left the hole there and did nothing until this year when I tore the truck down again to do my 97-01 Conversion and then I just fiberglassed over the Hole... I was going to make a Plate and bolt it on but figured I was not going to convert it back to manual so a permenant fix was best... Link to comment Share on other sites More sharing options...
valis Posted December 15, 2009 Share Posted December 15, 2009 I will likely be CNC'ing a plate and seal welding it over the hole when I do my conversion. Link to comment Share on other sites More sharing options...
