1999MJ Posted December 12, 2009 Share Posted December 12, 2009 looking to replace the sloppy tilt column in my 88 Chief with either a tight tilt or a non tilt. Color doesn't matter just need something lice with working turn switch and meys. Also need door lock cylinders with keys. PM me with what you have and a price to ship to 07422. Thanks Link to comment Share on other sites More sharing options...
mfpdm Posted December 13, 2009 Share Posted December 13, 2009 PM sent. :cheers: Link to comment Share on other sites More sharing options...
robfg67 Posted December 14, 2009 Share Posted December 14, 2009 Just tighten the bolts and buy a new lock cylinder for $13. Link to comment Share on other sites More sharing options...
1999MJ Posted December 15, 2009 Author Share Posted December 15, 2009 Just tighten the bolts and buy a new lock cylinder for $13. what bolts are you refering to my friend? Link to comment Share on other sites More sharing options...
mfpdm Posted December 15, 2009 Share Posted December 15, 2009 Just tighten the bolts and buy a new lock cylinder for $13. what bolts are you refering to my friend? The four reverse torx in the tilt collar. :cheers: Link to comment Share on other sites More sharing options...
Jeepman Posted December 15, 2009 Share Posted December 15, 2009 Yup Just tighten the bolts and replace the cylinder... Here is a link to repair the column, Ignore that the column being repaired is a CJ column as they are basically the same GM column... http://www.epiccomputer.com/dale/jeepjunk/tilt/tilt.html Link to comment Share on other sites More sharing options...
