yep my tranny leaks like a stuck pig gear oil every wear i think it might be a bearing,bushing or seal i was leaving melbourne fl to go back home to georgia and 4 to 5 hours into the ride i stoped fer gas and a big ole puddle sittin under it :headpop: :headpop:
which trans? is it coming from the front of the trans or the rear?
and are you sure it's not a puddle of engine oil coming from the rear main seal? I ask only because what you experienced is very rare. just want to be certain. :thumbsup:
I had a leaky rear seal in my tranny because of a worn universal joint in my drive shaft. About an hours work and I had a much smoother ride and no leaks.
Later on that year, I had a main seal on my engine go. That required pulling the tranny but while it was out, I did the front seal of the tranny as well as the main on my engine.
The rear tranny seal is a breeze!
its real thick fluid black coming from the bell of the tranny and when i was driving i heard a cracking noise the fluid isnt motor oil its to thick its gear oil
