banjobill80 Posted December 7, 2009 Share Posted December 7, 2009 Hey fellas I have an 86 mj with the 2.8 some may remember I was kickin around options on replaceing the 2.8 with something else. Well I found a gm 2.8 crate motor with 20K miles on it for 200 bucks so I decided to go that route. Now my next question is on induction. have any here used one of the weber carb conversions seen on ebay and else where. I also have pondered putting an eldebroke intake with a holey 390 4bbl carb any here done that? I will be stripeing the vacume lines and all that garbage off the motor as by the time I have it running it will be echeck exsempt :headpop: so I thought of rebuilding the original carb but it looks a bit crapy and problematic. Any thoughts Thanks Fellas Link to comment Share on other sites More sharing options...
Pete M Posted December 7, 2009 Share Posted December 7, 2009 don't waste any time/money on the stock carb. :thumbsup: Link to comment Share on other sites More sharing options...
kar120c Posted December 7, 2009 Share Posted December 7, 2009 I'm partial to Weber carbs but they can be a PITA to tune properly. A lot of times to properly tune them you have to swap out jets. If you want a weber, I'd highly recommend these guys. www.carburetion.com I've bought from them before and they have the cheapest prices for webers, parts, and conversion kits anywhere that I've seen. A Holley would be a good choice too, they are easy to work on and you can get a lots of parts, jets, valves, etc. at auto part stores. Link to comment Share on other sites More sharing options...
Eagle Posted December 7, 2009 Share Posted December 7, 2009 I'd go for the Holley. Link to comment Share on other sites More sharing options...
