Radiator Replacement recommendation
Tried the 3-cores, 2-cores, the all aluminum single core worked by far the best to keep my stroker cool along with the Hesco hi-flow pump. It's bolt-in for open and closed systems, and has the bung hole for the Renix temp sensor. Been four years now, still all is well.
http://www.alumrad.com/dblpass.html
The Jeep Cherokee model #9168
  • 4 months later...
E-bay. I picked up a new rad for $67 and converted my '90 4.0L to an open system. Mine leaked at the rad and the old pressure bottle so the conversion was a no brainer for me. No change in temp,operation, or anything else except lack of leakage :)
x2
Mine runs cooler now and only gets to just below the halfway mark on the gauge max however, EVERYTHING in the system, except for the water pump was circa 1988.
I replaced all the hoses, and eliminated the heater control valve. Plumbed the heater core direct (only two hoses now there), and capped the vacuum line.
Lack of price on that page scares me. :D
(& I bet you thought about polishing it to a chrome like finish before installing it. :yes: )
AFAIR, it was about $130 shipped.
Didn't just think about it, I DID it! :D Only you can't see how shiny it is because it's covered by the support bracket. But I know it's there. 8)
