xflowdaboi352 Posted November 19, 2009 Posted November 19, 2009 left rear seems to be sagging quite a bit? Any body got and advice
LEAD_NOT_FOLLOW Posted November 19, 2009 Posted November 19, 2009 This is typical of the MJ for the simple fact that the fuel tank as well as the most use (aka if you use your Jeep, you'll always have a driver) is on that side.
xflowdaboi352 Posted November 20, 2009 Author Posted November 20, 2009 I mean it sits like two inches lower with and empty tank of gas and no driver
Eagle Posted November 20, 2009 Posted November 20, 2009 left rear seems to be sagging quite a bit? Any body got and advice Check the left spring for a broken leaf.
