Jakeman17 Posted November 15, 2009 Share Posted November 15, 2009 I just broke something. this is the PCV right? Image Not Found ]Image Not Found i gotta have it running for school tomorrow Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 15, 2009 Share Posted November 15, 2009 Nope, that's a ventilation line. Engine vaccume. Just tape it back together and get one at the junk yard next time you go. All those lines get really brittle and snap like that, be careful moving them in the future... CW Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 15, 2009 Author Share Posted November 15, 2009 Nope, that's a ventilation line. Engine vaccume. Just tape it back together and get one at the junk yard next time you go. All those lines get really brittle and snap like that, be careful moving them in the future... CW ok sweet. yes i was just looking at it make sense now. Link to comment Share on other sites More sharing options...
MiNi Beast Posted November 15, 2009 Share Posted November 15, 2009 :rotfl2: :rotfl2: :rotfl2: :rotfl2: :rotfl2: :rotfl2: Link to comment Share on other sites More sharing options...
freakjeep93 Posted November 15, 2009 Share Posted November 15, 2009 hey id probably do the same thing Link to comment Share on other sites More sharing options...
pilotblake Posted November 15, 2009 Share Posted November 15, 2009 Nothing alittle Duct Tape won't fix. I had to do that mod to my cherokee as well. :thumbsup: Link to comment Share on other sites More sharing options...
Eagle Posted November 15, 2009 Share Posted November 15, 2009 For reference -- the 4.0L does not have a PCV. Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 15, 2009 Author Share Posted November 15, 2009 For reference -- the 4.0L does not have a PCV. I see that it has a CCV Link to comment Share on other sites More sharing options...
Eagle Posted November 16, 2009 Share Posted November 16, 2009 For reference -- the 4.0L does not have a PCV. I see that it has a CCV Correct. And the CCV system is a pair of open tubes. "PCV" typically implies a PCV valve -- which you won't find on a Jeep 4.0L engine. (I'm not convinced that was a good design decision, but it is what it is.) Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 16, 2009 Author Share Posted November 16, 2009 Ok so new problem. I was driving to school after getting onto 355 there was a bad grinding sounds. So I baby'ed it to school while getting off 355 on to army trail I got to hit brakes pedal hits the floor but if I pump it enough times it will stop and if I push it all th way it stop bearly Link to comment Share on other sites More sharing options...
Eagle Posted November 16, 2009 Share Posted November 16, 2009 Ok so new problem. I was driving to school after getting onto 355 there was a bad grinding sounds. So I baby'ed it to school while getting off 355 on to army trail I got to hit brakes pedal hits the floor but if I pump it enough times it will stop and if I push it all th way it stop bearly Start by opening the top on the master cylinder. There are two chambers. See if one of them is empty. The big chamber feeds the front brakes, the smaller chamber feeds the rear brakes. Once you figure out which end lost brakes, start tracing lines until you find where one popped. Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 16, 2009 Author Share Posted November 16, 2009 It is getting towed to a friends shop to have them look. I was looking did see any bad brake lines. I thnik my hubs are bad Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 It is getting towed to a friends shop to have them look. I was looking did see any bad brake lines. I thnik my hubs are bad :doh: How tight did you re-torque your hubs to? You didn't crank on them did you? Rob L. Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 16, 2009 Author Share Posted November 16, 2009 No just a little added lest than a ful turn Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 No just a little added lest than a ful turn Ok. Did you figure out what you broke? Rob L. Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 16, 2009 Author Share Posted November 16, 2009 No have not had a chance too look probably won't get to until the shop Link to comment Share on other sites More sharing options...
Automan2164 Posted November 16, 2009 Share Posted November 16, 2009 No have not had a chance too look probably won't get to until the shop Its weird that the brakes would act like that and there be grinding... Hmm... Rob L. :hmm: Link to comment Share on other sites More sharing options...
Jakeman17 Posted November 16, 2009 Author Share Posted November 16, 2009 I know I'm thinking it is Hubs and brakes Link to comment Share on other sites More sharing options...
Lenard Posted November 16, 2009 Share Posted November 16, 2009 For reference -- the 4.0L does not have a PCV. I see that it has a CCV Correct. And the CCV system is a pair of open tubes. "PCV" typically implies a PCV valve -- which you won't find on a Jeep 4.0L engine. (I'm not convinced that was a good design decision, but it is what it is.) :hijack: that same hose on my 4.0 is blowing oil out, so i just need to re-place the CCV? Link to comment Share on other sites More sharing options...
