2.5 info
Physically -- yes. It's the same engine. However, the '86 has the older Renix throttle body injection system (and corresponding ignition), and the 95 Wrangler has the newer Mopar multi-port injection (and corresponding ignition). If you're willing to swap over the woring and keep the newer MPFI, it's worth several horsepower and makes it a much more driveable package.
thanks for the reply i want to use renix and original wiring and ignition this is just a truck i use to plow my drive and run around in don't want to get to crazy on this one I'm in the middle of converting my f450 from gas to diesel need a easy one next so I'm taking it that my old accessories will work on the 95
