driveline vibration
I have had a driveline vibration between 45 and 55 mph for some time. I have replaced all of the u-joints but nothing changed. I have noticed that it seems to be getting worse, especially if I pull a small utility trailer.
Any suggestions would be greatly appreciated!
Conversely, my 2000 XJ 5-speed has a horrible vibration (not shimmy ... vibration) above about 40 or 45 MPH that's caused by driveshaft angles. Mine has the Up Country suspension. The factory wanted to put a transfer case drop on it, which to me is a band-aid approach. Eventually, I'll get around to putting a short shaft conversion on the transfer case, but for now I just keep an easy foot on the loud peddle to avoid stressing the u-joints any more than necessary.
My ill-fated 1999 WJ was even worse. That was an Up Country model, too.
Since the OP didn't specify, I'm wondering if the axle might be a replacement, and possible the spring perches weren't placed at the correct angle. We need more information.
New tires did not entirely solve the problem, although I noticed that if I accelerate hard the vibration is very noticeable. If I let off of the gas and coast, the vibration is very noticeable. But if I accelerate very slowly the vibration is hardly noticeable.
Truck is completely stock, new u-joints throughout. Had new ring gear and pinion installed a year ago.
I had the same driveline vibration at 35-45 MPH that drove me crazy for about four months. Pinion angle was perfect, new tires new u-joints, even a new driveshaft. The problem turned out to be in the differential after I regeared. I screwed up setting the pinion preload wrong by not using a new crush sleeve. :fs1:
I then had a shop that knew what they were doing re-install the gears and no more vibes.
