DirtyComanche Posted September 11, 2006 Share Posted September 11, 2006 My steering just isn't going to work unless I go highsteer... This is for the Ford D44 - with waggy outers. So, what ya think? I can get a set of flat-top chevy knuckles out of the boneyard. Then I need arms. Recomendations? And I need to get the knuckles machined (might be pricey). Although, do I have to get the driver's side machined? It is already flat. Flat enough? Or should it be honed down? Link to comment Share on other sites More sharing options...
Hot Rod Jeep Posted September 11, 2006 Share Posted September 11, 2006 Why can't you just use a Ford steering set up? Doesn't the drag link hook to the tie rod? I've gotta hunt me a passenser side flat top myself, I'm using a Chevy 44 front. If you go that route I've got a drivers side Chevy 44 knuckle I'd sell you pretty cheap. Just let me know if you need it. I don't think you have to machine the drivers side. 8) Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 11, 2006 Author Share Posted September 11, 2006 I can't use ford knuckles because the spindle bolt pattern is wrong, and thus my brakes won't fot or anything else. Link to comment Share on other sites More sharing options...
Bounty Hunter Posted September 11, 2006 Share Posted September 11, 2006 The DS Chevy is already flattop, no work required. The PS is a little tougher to come by, most common in '73-'75 Wagoneer which is what mine came out of. Check out www.sky-manufacturing.com and click on the Chevy/Ford link for steering arms. They'll machine a knuckle for highsteer for $45 if you provide the knuckle. Link to comment Share on other sites More sharing options...
Guest Hotrodjeep Posted September 11, 2006 Share Posted September 11, 2006 That's true, the Ford spindles are 5 bolt. If you can figure it out w/o highsteer I've got a pair of Chevy knuckles, but the passenger side is non-flat top. I'll let you have them cheap since you're a club member if you want them both or just the DS. There's a JY here that has 2 flat top front ends, but they won't part them out. 8) Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 11, 2006 Author Share Posted September 11, 2006 Thanks, but I don't need 'em. Pick'n'pull has a truck, unless it's been pirated or crushed. :cheers: Link to comment Share on other sites More sharing options...
jeepmj_tj Posted September 12, 2006 Share Posted September 12, 2006 you can just do cross over steering to save some cash. just use the stock waggy tie rod in stock location over the knuckle and just get a flat top and high steer arm for the pass. side.. thats what i did Link to comment Share on other sites More sharing options...
DirtyComanche Posted September 12, 2006 Author Share Posted September 12, 2006 It's not really much of a savings to just get a passenger side flat top. That's the one that will cost me the $. Machine work is NOT cheap around here. If I run the coils I could just flip the Tie Rod, and with the DP arm it'd probably be alright. Hmm. Link to comment Share on other sites More sharing options...
jeepmj_tj Posted September 13, 2006 Share Posted September 13, 2006 search around on the net... parts mike or something like that, usually has pretty good deals on flat top knuckles with highsteer arms.. all machined ready to go.. I have a local guy that i got my knuckle and highsteer arm from plus he machined it for me.. like $185 but finding those knuckles around here are getting harder and harder to find. Link to comment Share on other sites More sharing options...
