cluricaunne Posted November 2, 2009 Share Posted November 2, 2009 Okay, I know that I have the puke goat 5 speed trans with a 231, not sure if I have a 35 or 44 under the rear end, but I seem to be having issues getting the tcase to engage. I pull the lever to put it in gear, and about 10% of the time, it works like it should. The rest of the time, it drops my entire drivetrain into neutral, and the only gear I can get results out of is 2H. Anyone have any ideas on where I should start looking for a problem (I'm thinking the linkage, but who knows??) Link to comment Share on other sites More sharing options...
Red 1989 MJ Posted November 2, 2009 Share Posted November 2, 2009 I experience that, too much play on the linkage. Did you check the linkage under you truck ? On my truck that was my problem. :roll: Link to comment Share on other sites More sharing options...
Pete M Posted November 2, 2009 Share Posted November 2, 2009 Hopefully it's not due to a rusted out floor causing too much extra movement. :( If not, then this it the procedure for adjusting the linkage. :thumbsup: Link to comment Share on other sites More sharing options...
cracker Posted November 2, 2009 Share Posted November 2, 2009 Check your motor mounts as well. Usually the drivers side goes bad due to the heat. I had an issue years ago was a shot motor mount that would allow the drivetrain to shift just enough to shift my TC. Link to comment Share on other sites More sharing options...
johnnybebad Posted November 3, 2009 Share Posted November 3, 2009 could be a number of things but they all point in the same direction... LINKAGE either the rod that engages the 231`s shift lever is bent, out of whack, the bushings are shot, or the whole thing could be shot. if you crawl under there with the vehicle in PARK,turned off, and the wheels blocked, and have a friend try to shift from 2hi-4hi, you should get an idea of how the linkage works, and what may be causing it to bind. Link to comment Share on other sites More sharing options...
cluricaunne Posted November 3, 2009 Author Share Posted November 3, 2009 awesome, thanks guys, pretty much what I figured, but thought it couldn't hurt to check. Now I just have to get my lazy @$$ under the truck and fix it... lol :popcorn: Link to comment Share on other sites More sharing options...
