ocean Posted October 28, 2009 Share Posted October 28, 2009 just curious, I thought they did but there's a foot of wet snow on the ground and I don't really want to get wet. LOL (And why would checker auto not carry a replacement CPS, or be able to order one? Is it a dealer direct sort of thing?) What are the symptoms of a CPS going bad? Thanks for the replies Link to comment Share on other sites More sharing options...
Geonovast Posted October 28, 2009 Share Posted October 28, 2009 Yes you have a CPS. Bonus of the 2.5 is you don't have to crawl on the ground to change it. Symptoms are usually a no-start, or randomly dying while driving. It's the same part for a 4.0. Link to comment Share on other sites More sharing options...
Geonovast Posted October 28, 2009 Share Posted October 28, 2009 Oh, and I'll take your snow if you don't want it. This'll be my first winter away from WI and I think I'm gonna go through withdrawal down here in the depths of Missouri. Link to comment Share on other sites More sharing options...
ocean Posted October 29, 2009 Author Share Posted October 29, 2009 thanks geo snow...? you can have all you want/ where do you get another CPS?.... NAPA? Link to comment Share on other sites More sharing options...
Geonovast Posted October 29, 2009 Share Posted October 29, 2009 You can either grab one off a junkyard XJ/MJ or most parts stores will be able to get you a new one for around 60-70 bucks. Link to comment Share on other sites More sharing options...
Jakeman17 Posted October 29, 2009 Share Posted October 29, 2009 Nice has died a few times but i thought i just let of clutch. I swear i didnt though Link to comment Share on other sites More sharing options...
Geonovast Posted October 29, 2009 Share Posted October 29, 2009 My first two XJs had a habit of dying when you'd put in the clutch. It wasn't a CPS problem, they just had bad IACs. Link to comment Share on other sites More sharing options...
Jakeman17 Posted October 29, 2009 Share Posted October 29, 2009 My first two XJs had a habit of dying when you'd put in the clutch. It wasn't a CPS problem, they just had bad IACs. well I'm not fixing anything I'm just driving it now. Wel i might figure out where my oil leak is from Link to comment Share on other sites More sharing options...
Geonovast Posted October 29, 2009 Share Posted October 29, 2009 You can clean/change an IAC in no time at all. Link to comment Share on other sites More sharing options...
Jakeman17 Posted October 29, 2009 Share Posted October 29, 2009 You can clean/change an IAC in no time at all. cheep? Link to comment Share on other sites More sharing options...
Geonovast Posted October 29, 2009 Share Posted October 29, 2009 I've never bought one, but to clean it, it'll cost you a can of O2 sensor safe throttle body cleaner, which usually run about 4 bucks. Pop the throttle body off, spray it, scrub it all down with an old toothbrush, wipe it out and throw it back on. Probably be a good idea to pull the IAC out to clean it up. Link to comment Share on other sites More sharing options...
Jakeman17 Posted October 29, 2009 Share Posted October 29, 2009 I've never bought one, but to clean it, it'll cost you a can of O2 sensor safe throttle body cleaner, which usually run about 4 bucks. Pop the throttle body off, spray it, scrub it all down with an old toothbrush, wipe it out and throw it back on. Probably be a good idea to pull the IAC out to clean it up. ok ill try that tomorrow. :cheers: Link to comment Share on other sites More sharing options...
Jakeman17 Posted October 29, 2009 Share Posted October 29, 2009 I cleaned it all today and it seems to idle better but i will see after if completely cools down. I did die on me today after school. I started it. left my spot got halfway down the aisle and pushed the clutch all the way in and it died. it had a hard time staying alive it seemed like but after warm up it was perfect Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 30, 2009 Share Posted October 30, 2009 I cleaned it all today and it seems to idle better but i will see after if completely cools down.I did die on me today after school. I started it. left my spot got halfway down the aisle and pushed the clutch all the way in and it died. it had a hard time staying alive it seemed like but after warm up it was perfect a low idle or running poorly isn't normally associated with the cutting off of a CPS dying, it's more like someone shut the switch off. sounds more like IAC or plugs Link to comment Share on other sites More sharing options...
Jakeman17 Posted October 30, 2009 Share Posted October 30, 2009 Clean the IAC its run so much smoother next is plugs though Link to comment Share on other sites More sharing options...
