xj_dummy Posted October 14, 2009 Share Posted October 14, 2009 I recently changed my pcv valve and new rubber gasket from the dealer, because my old one was spraying oil all over the valve cover. Any way, my idle went up to 1100 rpm from 700 rpm. Is this Normal? I really don't know because when I got the truck it had a loose rubber gasket and PCV valve. Can you Help me? :dunce: Link to comment Share on other sites More sharing options...
Pete M Posted October 15, 2009 Share Posted October 15, 2009 might be a vacuum leak. did you bump anything? double check. Link to comment Share on other sites More sharing options...
aemsee Posted October 15, 2009 Share Posted October 15, 2009 Could be the wrong PCV. Pull it and plug the opening with your finger to see if the idle goes back down. Link to comment Share on other sites More sharing options...
