comanche87 Posted September 27, 2009 Posted September 27, 2009 Hey. Wanted to know how much of a pain in the but to install the ebrake handle in to a mj. I removed the old pedal setup. Has anyone done this yet? All thats in the truck is the rear cables.
MiNi Beast Posted September 27, 2009 Posted September 27, 2009 Should be cut a hole and bolt in thing. I sold a couple handles for guys to put in there MJ's. I still may have one as well as the full center section console as well, if needed anything.
mfpdm Posted September 27, 2009 Posted September 27, 2009 The older set up will need a hole cut and a new cable made or mod to make it work. Shelbyluv used the newer 97+ in his build. Here's the link and pic. viewtopic.php?f=7&t=11834&start=45 I at one time thought about this mod but it takes away space that could be way more useful for other things. :cheers:
