sureshot007 Posted September 22, 2009 Share Posted September 22, 2009 I'm looking at buying a set of the Bilstein 7100s, but since I'm not lifted, nor ever plan to be, I'm not sure which part number to get. Their website doesn't even have Comanche listed as a vehicle. All of the options for Cherokee are for 3-4" lift applications. Does anyone have any idea what I should get for stock replacement? EDIT: it's 2wd if it makes a difference. Link to comment Share on other sites More sharing options...
89eliminator Posted September 23, 2009 Share Posted September 23, 2009 good luck finding a shock. i don't know the collapsed and extended lengths of a stock shock but I'm guessing there are small. best bed would be to measure them and go shopping. here is where i got my bilsteins http://eshocks.com/ Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted September 23, 2009 Share Posted September 23, 2009 I'm looking at buying a set of the Bilstein 7100s, but since I'm not lifted, nor ever plan to be, I'm not sure which part number to get. Their website doesn't even have Comanche listed as a vehicle. All of the options for Cherokee are for 3-4" lift applications. Does anyone have any idea what I should get for stock replacement? EDIT: it's 2wd if it makes a difference. Good Q - been looking around myself. Link to comment Share on other sites More sharing options...
dakineJ Posted September 24, 2009 Share Posted September 24, 2009 I keep forgetting the length of the stock shock,but it would be as simple as taking one off and measuring the compressed and extended length's. I think it's about 7" of travel ? Besides the application specific shocks,Bilstein has shocks listed by length, 6-14 inch's of travel IIRC, as well as several different choices of valving,with or without a resavoir,bolt top,bushing,or heim end.They will probably do custom orders to. The 7100 is a great shock and I would totaly recomend it, night and day over anything stock. Link to comment Share on other sites More sharing options...
sureshot007 Posted September 24, 2009 Author Share Posted September 24, 2009 http://www.eshocks.com/bil_ORvh.asp?Ser ... &SubChar=Q I think these will do the trick. I measured last night and they have about 7" of travel. Link to comment Share on other sites More sharing options...
89eliminator Posted September 25, 2009 Share Posted September 25, 2009 http://www.eshocks.com/bil_ORvh.asp?Series_Index=Q3&Length_Index=9Q4&Manf=All&SubChar=Q I think these will do the trick. I measured last night and they have about 7" of travel. what was the collapsed length of the stock shock? Link to comment Share on other sites More sharing options...
sureshot007 Posted September 25, 2009 Author Share Posted September 25, 2009 The ones that were on there were about 14" in the rear and about 15" in the front - and that was just measuring from the bottom of the shock tube to the tip of the piston, no including the bushings on the ends. Link to comment Share on other sites More sharing options...
cherokee Posted September 25, 2009 Share Posted September 25, 2009 You would probably be ok with shocks meant for 0-3" of lift. In fact (at least for the front), you'll find that the extended and compressed measurements for a shock sold for a 3" lift will match or be extremely close to the stock shock measurements. The gabriel shock co. has (or used to at least) an online pdf file of specs for all the shocks they make. Too bad I never liked their shocks. Link to comment Share on other sites More sharing options...
