xflowdaboi352 Posted September 20, 2009 Share Posted September 20, 2009 well today we took the truck out and reverse was working fine and the last hole on the way out of the woods we got stuck so i put it in 4lo and tryed reverseing out the tires just spun same thing going forward so i used the winch to get out when i got out i went to put bak in 2wd and went to reverse and it like start virbrate real bad and dosent go no wear but if u just let it idle it will reverse fine at idle but wil not doing any thing when u give it gad???? :huh???: Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 20, 2009 Share Posted September 20, 2009 What?? Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 20, 2009 Author Share Posted September 20, 2009 when u put it in reverse it goes in u can feel lunge backwards when u let off the brake but when u give it gas nothing happens just revs up and like vibrates it hard to explain Link to comment Share on other sites More sharing options...
mvusse Posted September 20, 2009 Share Posted September 20, 2009 Maybe if you use proper spelling and punctuation we can figure out what you're trying to say. Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 20, 2009 Author Share Posted September 20, 2009 Mayb ill just take it to a tranmission shop. ;) Link to comment Share on other sites More sharing options...
64 Cheyenne Posted September 20, 2009 Share Posted September 20, 2009 I understood that last post just fine,what people are saying is,post as if you are doing a term paper,not texting your girlfriend. Lots of people on this board are more than willing to help,It's just we need to communicate in language that can be understood. Personally,I don't "Text". Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 21, 2009 Author Share Posted September 21, 2009 oh ok well the problem is that when it goes into to reverse it just revs up and vibrates and goes barely backwards Any ideas of what it could be? ;) Link to comment Share on other sites More sharing options...
aemsee Posted September 21, 2009 Share Posted September 21, 2009 stick or auto? Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 21, 2009 Author Share Posted September 21, 2009 Its and 1988 4.0 4x4 auto sorry for not stateing that. :dunce: Link to comment Share on other sites More sharing options...
mvusse Posted September 21, 2009 Share Posted September 21, 2009 I think you still may want to go the the transmission shop. I don't know much about automatic transmissions, but it sounds like reverse is going out. Either a rebuild or a replacement. Let's hope I'm wrong and it's something simple. Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 21, 2009 Author Share Posted September 21, 2009 idk cuz it use to do it when u would first crank it up but if u would let it sit and run for a min it would work with no problems but it didnt vibrate like it does now. :shake: Link to comment Share on other sites More sharing options...
Automan2164 Posted September 21, 2009 Share Posted September 21, 2009 Probably because the trans had to warm up, it was on the verge of failure. Now, after an offroad thrashing, its finally gave up the ghost. Rob L. Link to comment Share on other sites More sharing options...
mvusse Posted September 21, 2009 Share Posted September 21, 2009 Just to rule out the obvious, you did check the transmission fluid level, right? Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 21, 2009 Author Share Posted September 21, 2009 yes trans fluid is full. Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 22, 2009 Author Share Posted September 22, 2009 Well it seems to be the transfer case cause that wear it seem to making some noise from i don't havent had time to take to the shop. :ack: Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted September 25, 2009 Author Share Posted September 25, 2009 well i got a price today to rebuild it and was told $800.00 :( Link to comment Share on other sites More sharing options...
