dancome433 Posted September 11, 2009 Share Posted September 11, 2009 will an extended driveshaft off of an automatic comanche work on my comanche with the ba10/5? using the same amount of lift, same axles, same tcase, same everything, different trans Link to comment Share on other sites More sharing options...
Geonovast Posted September 11, 2009 Share Posted September 11, 2009 It might fit in, but you're going to lose a lot of spline engagement. You can try putting it in, but I think the yoke's going to be abit further out than you want. Link to comment Share on other sites More sharing options...
Pete M Posted September 11, 2009 Share Posted September 11, 2009 the auto trans is about 1" longer than the sticks, so the driveshaft would be one inch shorter. Link to comment Share on other sites More sharing options...
dancome433 Posted September 11, 2009 Author Share Posted September 11, 2009 cool thanks you guys Link to comment Share on other sites More sharing options...
mvusse Posted September 11, 2009 Share Posted September 11, 2009 Try a 2wd drive shaft if you can find one, and have it shortened. Link to comment Share on other sites More sharing options...
dancome433 Posted September 12, 2009 Author Share Posted September 12, 2009 Try a 2wd drive shaft if you can find one, and have it shortened. yea ill be on the look out for one, Link to comment Share on other sites More sharing options...
