daltonmcgill7 Posted August 15, 2009 Share Posted August 15, 2009 my 1989 5spd is goin into gear but won't mov antidisestablishmentarianism do u think it is its been sitting for 5 years with the ebarke on but i released it and it still won't move keep in mind I'm only 14 i turn 15 n januay so I'm tyin to fix it by then antidisestablishmentarianism should i try :fs1: Link to comment Share on other sites More sharing options...
NWPhotog Posted August 15, 2009 Share Posted August 15, 2009 Sounds like the emergency brake is rusted in the on position. I would pull the rear drums and make sure they are releasing. Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 15, 2009 Author Share Posted August 15, 2009 thnaks ill go try that Link to comment Share on other sites More sharing options...
Eagle Posted August 15, 2009 Share Posted August 15, 2009 After sitting for 5 years, you have a lot of potential problems. 1. The parking brake cables are probably rusted. If the parking brake was left on, that would leave the cable rusted so that it hold the brake engaged even when you release the foot peddle. 2. The rear brake shoes may be rusted to the drums. If so, you will probably have to destroy the shoes to get the drums off. 3. The front pads are probably rusted to the rotors. You should pull the calipers, check the pads, and buff as much rust as you can off the rotors with a wire wheel or sanding disk, then reinstall. Link to comment Share on other sites More sharing options...
dakal Posted August 15, 2009 Share Posted August 15, 2009 also, my clutch, flywheel, whatever rusted together. so we put it in gear , pushed it and popped the clutch to free it. Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 15, 2009 Author Share Posted August 15, 2009 i got 1 tire offbut 1 of the is like rusted to the drum any ideas on how tobreak it loose?? Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 15, 2009 Author Share Posted August 15, 2009 nvm i go it off but the back brake is on antidisestablishmentarianism should i do to break it free :dunno: Link to comment Share on other sites More sharing options...
Eagle Posted August 15, 2009 Share Posted August 15, 2009 nvm i go it off but the back brake is on antidisestablishmentarianism should i do to break it free :dunno: I usually use a 2 or 3-pound sledge hammer applied to the sidewall of the tire from the back side (i.e. from under the vehicle). The wheel should be jacked up, and since you'll be lying on the ground under the chassis, you need to be sure the truck is well supported. If you care about the wheel, be careful not to hit it. I had one MJ a year or so ago where that worked for three out of four, but it wouldn't "pop" the right front. Fortunately, that truck had stock steel rims and I have plenty of those, so I gave up hitting the tire and used a full-size (long handle rather than one-hand) sledge hammer applied directly to the flange of the rim. I destroyed the rim pretty thoroughly before it came loose. Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 15, 2009 Author Share Posted August 15, 2009 nvm i go it off but the back brake is on antidisestablishmentarianism should i do to break it free :dunno: I usually use a 2 or 3-pound sledge hammer applied to the sidewall of the tire from the back side (i.e. from under the vehicle). The wheel should be jacked up, and since you'll be lying on the ground under the chassis, you need to be sure the truck is well supported. If you care about the wheel, be careful not to hit it. I had one MJ a year or so ago where that worked for three out of four, but it wouldn't "pop" the right front. Fortunately, that truck had stock steel rims and I have plenty of those, so I gave up hitting the tire and used a full-size (long handle rather than one-hand) sledge hammer applied directly to the flange of the rim. I destroyed the rim pretty thoroughly before it came loose. i got the back brakes loose now i only got 2 get the right front thanks for the help Link to comment Share on other sites More sharing options...
Myron Posted August 16, 2009 Share Posted August 16, 2009 Soak whatever won't come loose in PB blaster. If it doesn't work the first time keep on for days. It should eventually break it loose. Also now that you have your rears off you could try to drive the Jeep forward or backwards to break the fronts free, there is less holding it back now. If you have 4x4 I would try using that as well. Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 16, 2009 Author Share Posted August 16, 2009 i got all thebrakes loose :banana: but the clutch is bad :grrrr: where cn i get a new 1 my dad is gonna put iton 4 me Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 16, 2009 Author Share Posted August 16, 2009 also do u think rhinolining my whole truck would look good 8) Link to comment Share on other sites More sharing options...
dakal Posted August 17, 2009 Share Posted August 17, 2009 why do you want to? Link to comment Share on other sites More sharing options...
daltonmcgill7 Posted August 17, 2009 Author Share Posted August 17, 2009 why do you want to? beacause it already has dents in it and the clearcoat is pellin and cuz i will also be huntin out of it so if i do paint it it will get scrached up so i thoughtr of rhinoliner Link to comment Share on other sites More sharing options...
dasbulliwagen Posted August 17, 2009 Share Posted August 17, 2009 Welcome to the club! We always love having new faces in here! But many of us are old timers, and find it very difficult to read texting language. Could you please please please type evrything out. I know for sure that there are some guys that won't even respond to such a message, making the Comanche Club a smaller resource to you. There is such a huge knowledge base here that I would hate to see it getting shorted to you for not fully typing. We love to see a new generation of guys loving and caring for our dear trucks. There really never has been anything else like them. As for your problems...looks like you have a great start so far getting it going. And yes, there are going to many more problems you are going to encounter bringing it back to life after sitting for five years. Just read everything you can from these pages and the builds in the projects section, and you will find everything your heart desires. There have been members who have used similar products like Rhino Line to cover their trucks. A guy that works in the body shop where I work just did it to his 2dr Cherokee and it looks great! There are several products on the market, some better than others, so when you are ready for it, start a new thread, or use our search function, and you will find what members have had good and bad luck with. And we absolutely love pictures! So if you can, post some for us. You will be loved by all if you do. Good luck getting going, and keep us posted! Link to comment Share on other sites More sharing options...
Myron Posted August 17, 2009 Share Posted August 17, 2009 i got all thebrakes loose :banana: but the clutch is bad :grrrr: where cn i get a new 1 my dad is gonna put iton 4 me Try Advance Auto Parts, O'Reiley Auto Parts, or Autozone. I prefer Advance, but any of them should either have it in stock or be able to get it usually in 1 business day by 9AM. Link to comment Share on other sites More sharing options...
