thejum57 Posted August 9, 2009 Share Posted August 9, 2009 I need to replace the brake rotors & pads on my 86 Comanche. When I go to look up prices, there is listed one piece, with studs, or two piece that slides over the existing studs. Does anyone know what an 86 2WD came with? I know I could take a wheel off & check, but I'm feeling a little lazy.....thanks. Link to comment Share on other sites More sharing options...
Automan2164 Posted August 9, 2009 Share Posted August 9, 2009 I believe the '86 2wd was a hubbed rotor, meaning the hub and rotor are a one piece assembly. Rob L. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 9, 2009 Share Posted August 9, 2009 All 2WD MJs - One Piece Rotor (solid rotor and hub) All 4WD MJs - Separate rotor and hub 1993 was the change year when all XJs received the same rotor. Link to comment Share on other sites More sharing options...
thejum57 Posted August 9, 2009 Author Share Posted August 9, 2009 Have I ever said you guys rock? :bowdown: Thanks for the info. Link to comment Share on other sites More sharing options...
reson46 Posted August 10, 2009 Share Posted August 10, 2009 hornbrod said: All 2WD MJs - One Piece Rotor (solid rotor and hub) Not true. My '91 has a separate rotor and hub. I know the earlier ones were one piece, but I don't know when they changed them. Willy Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 10, 2009 Share Posted August 10, 2009 Yes it's true. Both my 91 2WD MJ and a 2WD 92 XJ I had have the one-piece hub/rotor. The parts manual confirms this. 93 was the change year. Your 91 2WD must have been changed out to 93+ knuckles/hubs and rotors, or it's a prototype of some kind. Got any pics? Because I'd like to do this at some point in time. Link to comment Share on other sites More sharing options...
reson46 Posted August 10, 2009 Share Posted August 10, 2009 Interesting... :hmm: Now you have me thinking. I was pretty sure the rotor was separate when I was working on the brakes. But, I could be remembering wrong. All the D30s are starting to blur together.... :ack: I'll have to take a closer look when I get a chance. Willy Link to comment Share on other sites More sharing options...
Geonovast Posted August 10, 2009 Share Posted August 10, 2009 reson46 said: Interesting... :hmm: Now you have me thinking. I was pretty sure the rotor was separate when I was working on the brakes. But, I could be remembering wrong. All the D30s are starting to blur together.... :ack: I'll have to take a closer look when I get a chance. Willy They're not talking about a D30. They're talking about the 2wd axle. From what I understand, some of the 86 2wd fronts had a hub, with separate rotor, and a dummy axle shaft to go in the center. Then they went to the one piece bearing/rotor, and then sometime in the early-mid 90's they went back to the separate pieces. Link to comment Share on other sites More sharing options...
reson46 Posted August 10, 2009 Share Posted August 10, 2009 Geonovast said: They're not talking about a D30. They're talking about the 2wd axle. Yes, I realize that. I was attempting to state that the more I learn, the more I seem to forget. :oops: Willy Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 10, 2009 Share Posted August 10, 2009 reson46 said: I was attempting to state that the more I learn, the more I seem to forget. :oops: Willy No worries Willy - it only gets worse as you get older. :doh: :D Link to comment Share on other sites More sharing options...
dakineJ Posted August 11, 2009 Share Posted August 11, 2009 I've heard you can retrofit a unit bearing hub to a one peice knuckle.I was'nt aware they were on 86' 2WD's.I was wondering if the unit bearing would be stronger? Link to comment Share on other sites More sharing options...
1986Comanche Posted August 11, 2009 Share Posted August 11, 2009 thejum57 said: I need to replace the brake rotors & pads on my 86 Comanche. When I go to look up prices, there is listed one piece, with studs, or two piece that slides over the existing studs. Does anyone know what an 86 2WD came with? I know I could take a wheel off & check, but I'm feeling a little lazy.....thanks. My 1986 Comanche 2WD has the 2 piece rotors with the hubs seperate from the rotors. The 1986 Comanche 2WD could have either setup. I am not sure about the other years. My factory 1986 parts manual lists both setups for the 1986 Comanche 2WD. You will have to check yours to see which setup it has. I hope this info helps. Link to comment Share on other sites More sharing options...
mjeff87 Posted August 11, 2009 Share Posted August 11, 2009 I've seen them in the junkards from time to time as well, never checked what years they were. First one I saw made my head turn.....I thought whover owned it did some creative swapping of parts somewhere down the line. But then I saw a few others. Jeff Link to comment Share on other sites More sharing options...
dakineJ Posted August 11, 2009 Share Posted August 11, 2009 Geonovast said: From what I understand, some of the 86 2wd fronts had a hub, with separate rotor, and a dummy axle shaft to go in the center. Then they went to the one piece bearing/rotor, and then sometime in the early-mid 90's they went back to the separate pieces. Does anyone have pictures of the dummy shaft and how it mounts? Link to comment Share on other sites More sharing options...
