SaltyMJ Posted August 2, 2009 Share Posted August 2, 2009 I was taking my valve train off and need to remove the throttle body to get to a few bolts. Someone was helping me and he tried to remove the fuel lines and the brass connector snapped off inside the throttle body. So I need to find a new fuel line for that side. Anyone know where I can pick one up? I just need the part that is "quick disconnect" as the Haynes manual says. I'd like to avoid the jyard. Link to comment Share on other sites More sharing options...
JeffK Posted August 3, 2009 Share Posted August 3, 2009 I looked at several online sources, and nothing. Good luck, but short of finding someone locally to fab you one up, you're only choice may be the JY's. :cheers: Jeff Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 3, 2009 Share Posted August 3, 2009 I was taking my valve train off and need to remove the throttle body to get to a few bolts. Someone was helping me and he tried to remove the fuel lines and the brass connector snapped off inside the throttle body. So I need to find a new fuel line for that side. Anyone know where I can pick one up? I just need the part that is "quick disconnect" as the Haynes manual says. I'd like to avoid the jyard. Post a pic of the part(s) you need. Link to comment Share on other sites More sharing options...
Wildman Posted August 3, 2009 Share Posted August 3, 2009 Or....... http://www.classictube.com/index.asp But there on line shopping is being rebuilt now :fs1: You can call them. They carry brake lines, fuel line, and tranny line for the XJ, which all of the front lines are the same as the MJ. You said, you broke off the fuel line to the throttle body :hmm: Is this for a 2.5 engine??? Link to comment Share on other sites More sharing options...
SaltyMJ Posted August 3, 2009 Author Share Posted August 3, 2009 Actually I got the brass fitting off without tearing the line in half..it was on there good...so now I just need a new brass fitting and I should be good..I hope lol Thanks for the help though. Link to comment Share on other sites More sharing options...
JeffK Posted August 3, 2009 Share Posted August 3, 2009 Or....... http://www.classictube.com/index.asp But there on line shopping is being rebuilt now :fs1: You can call them. They carry brake lines, fuel line, and tranny line for the XJ, which all of the front lines are the same as the MJ. You said, you broke off the fuel line to the throttle body :hmm: Is this for a 2.5 engine??? Excellent site. Nice find. Link to comment Share on other sites More sharing options...
Wildman Posted August 6, 2009 Share Posted August 6, 2009 Excellent site. Nice find. Gee.......Thanks There located about 5 miles from where I'm at........We "locals" try to keep them busy :D And surprisingly, the Stainless lines are only a couple bucks more that the annealed steel lines :brows: Link to comment Share on other sites More sharing options...
