jeepthing07 Posted August 27, 2006 Share Posted August 27, 2006 anyone know the part number for the bearing inside the passengers side axle shaft on the Dana 30 with vacume disconnect? i can't find it anywhere i don't know if I'm looking in the wrong places or what 4wd hardware don't list it. quadratec don't list it. its the bearing thats in between the 2 shafts on the disconect side in the outter shaft. i posted this earlier but then i thought i found the bearing but it was the wrong one so I'm reposting it. Link to comment Share on other sites More sharing options...
pingpong Posted August 27, 2006 Share Posted August 27, 2006 There is no bearing in between the one holding the carrier and the unit bearing. There is a seal in there, but no bearing Link to comment Share on other sites More sharing options...
Bounty Hunter Posted August 27, 2006 Share Posted August 27, 2006 That's what I had thought, seal only on the disconnect. Link to comment Share on other sites More sharing options...
jeepthing07 Posted August 27, 2006 Author Share Posted August 27, 2006 I took a pic the bearing is inside the end of the outter shaft on the disconnect side. the cage is busted and about 5 rollers fell out. Image Not Found Link to comment Share on other sites More sharing options...
Pete M Posted August 27, 2006 Share Posted August 27, 2006 Sounds like a great opportunity to go to a solid shaft and 297s. :brows: Link to comment Share on other sites More sharing options...
jeepthing07 Posted August 28, 2006 Author Share Posted August 28, 2006 after spending all weekend looking on the net i finely found it its a INA bearing part number SCE108. Timken and BCA bearings share the same part number its a $4 bearing :D Link to comment Share on other sites More sharing options...
