how the hell do you put a tack in a 96 cherokee?????????
i can't figure this out and it is starting to get on my nerves :mad: . it says " green to the negative side of the coil" where the hell is that remember its a 96 4.0 ho
My 95 FSM illustrates a GRAY / LIGHT BLUE wire running from the PCM to the instrument cluster. This is for the stock tachometer. If you don't have this wire, the negative coil wire *should* be the black wire coming out of your ignition coil. Hope that helps. :thumbsup:
