NP231 Rebuild kit.
Hey guys. I'm looking at rebuild kits right now. There are a bunch out there on the interweb and i was hoping you guys could help me decide. I was originally looking at JB conversion's kit ( http://www.jbconversions.com/pages/prod ... index.html ) and they say that their kit is superior to their competitors, but they are a bit pricey... Should i go with them or buy from some place like 4wd.com or fourwheelparts.com or eastcoastgearsupply.com etc. etc. Thanks for the help guys! :cheers:
See how screwed the internals are before buying a rebuild kit. It might need more than that. In which case a new (used) low mileage case can be a better deal.
You also might want a chain if yours is sloppy.
I'd look around and compare kit contents before I bought one.
You also might need a special bearing puller to get the one front output bearing out as it is installed blind. The FSM has a number for the tool, but I'd sure Jeep would want eleventybillion dollars for it. Maybe somebody knows a good trick.
