landlubber Posted August 23, 2009 Author Share Posted August 23, 2009 Not without re-setting up the gears. does that mean I have to use the 3.07's, or just take out the posi element and put it on the 3.55's? this D30 is a HP axle, unlike the LP i have in the other MJ. 4x4 swap will have to wait for a while - next year or this winter most likely, unless someone wants to help me out. The posi cannot be swapped without re-setting up the gears. And gears are not swappable between LP and HP axles. Have you ever set up gears before? negative. just interested in the rear axles here to clarify. they are both stock. Link to comment Share on other sites More sharing options...
Pete M Posted August 23, 2009 Share Posted August 23, 2009 I don't recommend trying to swap gears or carriers then. It's a complicated process usually best left to the pros (and it's not cheap). I would use the 3.55 open axle and install a locker (the kind that replace the spider gears) like the Aussie. Link to comment Share on other sites More sharing options...
landlubber Posted August 23, 2009 Author Share Posted August 23, 2009 ok. will put that on the list. any specific ones to look for: ie. tried and true? thanks for the advice. Link to comment Share on other sites More sharing options...
Pete M Posted August 23, 2009 Share Posted August 23, 2009 I've read good things about the Aussie locker. Link to comment Share on other sites More sharing options...
mvusse Posted August 23, 2009 Share Posted August 23, 2009 I have had an Aussie in my front axle for 6 months now. Very happy with the off road performance. Amazing difference in traction! In 2wd on the road I don't even know it's there, except for the clicking sound when it ratchets to allow one wheel to overrun the other in sharp turns. Link to comment Share on other sites More sharing options...
