mnkyboy Posted July 12, 2009 Share Posted July 12, 2009 My brother is installing Dana 44s in his 95 YJ and said i could have his old axles if i can use them. they have 4.10 gears which my truck could really use,I know the front axle won't fit but would the gear set fit my axle. is the rear axle the same width or can i swap the gears and axles. Link to comment Share on other sites More sharing options...
Pete M Posted July 12, 2009 Share Posted July 12, 2009 Rear axle is the essentially the same Dana 35, only with different brackets welded on. Keep in mind that it's still just a Dana 35. Front can be converted if you weld on XJ/MJ stuff (might be tough with the YJ CAD mount). Unless you're capable of doing a gear set-up, you might want to re-think trying to swap gears yourself. It's not as easy as just bolting them in (it can cost between 100 and 300 per axle to get it done right). You can sell the pair and put them towards an Explorer 8.8 and an MJ/XJ Dana 30 with 4.10s already in them. Link to comment Share on other sites More sharing options...
mnkyboy Posted July 12, 2009 Author Share Posted July 12, 2009 so weld on perches on the rear and re gear the front. thats what i needed,swapping the gearing won't be a problem. Link to comment Share on other sites More sharing options...
