Shaking, Not DW
For a while now if I hit a bump at high speed (only highway) the front starts shaking but all I have to do is tap the brakes. I don't have to come to stop or even slow very much which is why I don't think it is DW. Well today it happened just going around a bend in the highway WITHOUT hitting a bump. I'm thinking it may be the ball joints (I have them to replace and also am putting new axle u-joints in). Do you think this is ball joint related or possibly a bent axle? All lug nuts are tight.
Bad uni-bearing? Have you jacked up a tire and checked for slop?
not in a while pete; since i checked the b-joints. I also have two new timken hubs that will be going on with the ball joints and u-joints jamminz.gif
