Nate C Posted July 9, 2009 Posted July 9, 2009 Anyone know how to get these out? I need to put them in the new motor I got coming. I yanked everything off & out of the way. The injectors seem like they're stuck in there. they're lose but just spin around. Very frustrating.
mnkyboy Posted July 9, 2009 Posted July 9, 2009 they should just pull out. there is an O-ring that seals them,this is why they spin. sometimes the o-rings get stuck making it hard to pull them. You also should replace the o-rings when you put them in your new engine,they are only a couple dollars for the set.
Oizarod115 Posted July 9, 2009 Posted July 9, 2009 if theyre really stuck use a prybar GENTLY at one end of the fuel rail and try to work them out one at a time, just be careful to not bust/fold anything. they ought to pull right out. lil lube goes a long ways ;)
