xComancheKidx Posted July 8, 2009 Share Posted July 8, 2009 what is the most desirable year xj seats for a bucket swap..also will any year center console fit? Link to comment Share on other sites More sharing options...
stormtrooper Posted July 8, 2009 Share Posted July 8, 2009 thats all personal opinon and yes all center consoles will fit Link to comment Share on other sites More sharing options...
lostissues Posted July 8, 2009 Share Posted July 8, 2009 Just by guessing I would say, black buckets from a two door Cherokee pre 95 maybe? not sure when they changed the floors around and that messed with the seat I believe. then after that any seat from a 2 door with the correct substructure because they fold forward and allow access to behind the seat. Link to comment Share on other sites More sharing options...
Pete M Posted July 9, 2009 Share Posted July 9, 2009 '84-~'95 two door with the straight (not curved) slider under them are the most direct swap into an MJ using the MJ's floor pedestals. 4-door seats don't tilt forward and the curved slider will sit you up a couple inches higher than stock. Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 9, 2009 Share Posted July 9, 2009 '84-~'95 two door with the straight (not curved) slider under them are the most direct swap into an MJ using the MJ's floor pedestals. 4-door seats don't tilt forward and the curved slider will sit you up a couple inches higher than stock. Agree w. Pete except the cutoff year for the seat redesign was 1994, although I suspect there was probably some overlap. The 93 and below 2-door buckets, especially from a Laredo or Limited XJ model since they hve the bigger side bolsters, are the easiest swap and are direct bolt-ons to the MJ bucket seat sliders. Mine are from a 2-door 90 XJ Laredo model. Very comfy too. :D Link to comment Share on other sites More sharing options...
