90eliminator Posted June 27, 2009 Share Posted June 27, 2009 driving down the road....headed home....and the truck just died, shifted into neutral and started it back up like normal... ran the rest of the way fine. It has done this once before. Any ideas....things to check.??? thanks Link to comment Share on other sites More sharing options...
JeffK Posted June 27, 2009 Share Posted June 27, 2009 My '92 XJ would do the same thing, turned out to be the crank sensor. Link to comment Share on other sites More sharing options...
jpdriver1 Posted June 27, 2009 Share Posted June 27, 2009 My '92 XJ would do the same thing, turned out to be the crank sensor. in the case of my '90, the wires had gotten crispy and were shorting out on the exhaust pipes --- I'm considering covering them with heat resistant loom material like racing vehicles. Link to comment Share on other sites More sharing options...
BLHTAZ Posted June 27, 2009 Share Posted June 27, 2009 That type of issue is typically the CPS. It will likely soon die on you and not start again. Link to comment Share on other sites More sharing options...
