shelbyluvv Posted June 12, 2009 Share Posted June 12, 2009 I'm just watching to see what it sales for. It looks like a hack job to me as well. There are some firewall mods that need to be address when doing the conversion. Mainly, the column is a inch hicher on the 97+ XJs, so you have to move tha hole up. Also the fuse bos is under the passenger kick panel and the factory hole needs to be modded to work with the XJ harness. Link to comment Share on other sites More sharing options...
BLHTAZ Posted June 12, 2009 Share Posted June 12, 2009 From his description, and what I can see in the pics, I would have to believe that this is a complete XJ front end with the bed and rear cab section from an MJ cut and welded on. The guy seems to have skills in fabrication, although his writing leaves much to be desired :teehee: . If the work is as good as it appears, I would say that it's worth $4000. :thumbsup: Link to comment Share on other sites More sharing options...
CEThomas Posted June 15, 2009 Share Posted June 15, 2009 Has not got back to me yet, must have seen us talking about it :banana: Link to comment Share on other sites More sharing options...
